Axle size 68 Plymouth Fury 3
Fury Rookie
Pa.
Hi Everyone
I need the dimensions of axle size for my 68 Fury. I need to find speedie sleeve as my driver side axle has a very small divet in it and is causing axle sleeve to leak Any help greatly appreciated
Thanks Frank
seal surface on axle shaft should be 1.550 inches ,, if the divot is small enough have you tried to fill it with JB Weld and sand it back to size . or take you axle to any bearing shop near you and they will measure the seal surface and may have a speedy sleeve available.
