Bonding metal patches
C Body Bob
Youngsville, NC
Got a couple of spots on my drag car FURYIOUS where I need a patch. Obviously non-structural. I have this stuff in my chemical cabinet. Says it bonds metal. Anyone ever use this. How well does it work.
Haven't used this stuff but googled it.
It don't think this is what you want to use.
I have used the 3M glue 08115 on the floor pan and trunk floor of my 66 Polara.
3 Years and still going strong.
Yes, i read and followed the instructions for best results:lol:
This what body shops use on many newer cars instead of welding. I have successfully used this to glue/bond aluminum and steel on my motorhome. You can find the applicator and replacement cartridges on eBay at a good price.
I forgot to mention that I used this on the trunk filler panels when installing the trunk floor with very good results.
As lead solder has been deleted from vehicle manufacturing, "panel bonding adhesive" has taken its place. Many used to be "aircraft grade"? Possibly even some "spot weld thru"? Look for "OEM approval", of similar, for best results?
Make sure you don't clamp too tight or you'll squeeze out the adhesive. Not sure about the 3m but the sem has little glass beads in it to prevent over clamping and the squeezing out of the glue.
I bonded two pieces of scrap metal together that’s the same thickness as the thickest piece I need to repair. I used the E6000 stuff. It says it needs 24 hours. I’m going to give it 72. See then if I can pull it apart. If I can’t then I’ll submerge in in water over night & try again to break it apart. I’ll let you know how the highly sophisticated test go’s. Also here is one area I’m wanting to patch.
That looks like a non structural area. You're going to have to blast/clean it anyway to use that panel bonding glue so I'd just mix up some Marglas filler (fibreglass strand reinforced bondo) to plug the hole, sculpt it up pretty and call it a day.
Kevin
Kevin
Trying to use stuff I got & I want to try this stuff. Low budget
