Are there different PSIs on mech pumps?? I have a holley 2 barrell...carb is flooding only after a few minutes of running! Fuel pump from NAPA...do you guys recommend a certain make, model? Any help would be appreciated...
Car starts up, runs for a few minutes and then you see fuel coming up on the primary side! Then stalls out...also white smoke from the carb when shut off. Weird s***...this only started happening when I changed out the pump??
Thanks, I guess I'm gonna have to take it apart and physically look at it...also the service manual is sorta vague but the float has to be set just right?? Maybe it's not parallel to the bottom of the air horn like it should be??
Before anything I would check the fuel pressure of the pump at the pump outlet. Then compare it to the max. fuel pressure that carb can handle. I have had the same thing happen to a new Eddy. If I remember right the carb max was 6 p.s.i. and the pump produced somewhere around 7- 7 1/2 p.s.i.
