carpet replacement 66 NewPort
BigCRig
colorado
time to replace the rug in my newport, any recommendations molded is probably the way to go how bout suppliers?
Once you put your molded carpet in don't be in a hurry to trim it and put the seats in. I put mine in and walked on it for a week while I did other interior work, that way there is no worry of having it pull out of the sill plates. Once I was ready to do the belts and seat I took an old soldering iron and ran it through the holes from under the car, not just the tip but the body of the iron. A couple I could only get the tip through from the bottom but opened them up from the top. Locating console brackets take a little more work.
Alan
I bought a set from Trim Parts as well.
Made by ACC. (Auto Custom Carpet)
I paid more for the mass backing. Makes the carpet much stiffer and helps with sound deadening.
I let it sit laid out for a couple of days and then in the car in the sun for a couple more.
Start in the center and work out. Fasten eveything down before you trim the sills or you'll end up short.
Hope the input helps.
John
