bluefury361
Has anyone got a good procedure to remove the distributor drive gear from a 383?
Wow...we think alike. I hope that's a good thing!I just use a screwdriver and screw it so it comes out, then use some long needle nose pliers to get the rest. If it's stuck like a lifter in the bore. Just give it a shot of Gumout or 2 to help release it. Good Luck
You gotta use what works, or is it simple minds think alike???Wow...we think alike. I hope that's a good thing!![]()
Thanks guys. I had removed the gear/shaft twice before using all the listed methods but it stuck good this time. Even a hooked wire wouldn't budge it. But as it turned out It was indexed correctly after all.
I'm having trouble getting the engine to catch and run after the reinstalling the heads for a valve job. I've got fuel and fire so was looking hard at timing. Rotor comes up on the mark, firing order correct, points opening when they should. I pulled the left valve cover and power stroke is right on #1. I added a little trans fluid down the carb to try and seal the rings and boost compression, which seems to be fine. Just doesn't want to catch and run. I've had this issue before on mopar big blocks initial start.
LOL!Here we go!
Liable to get a Verbal Whacking for this one.
The Old Saying is: Great Minds think Alike, But Fools rarely Differ. LOL
Tony.M
When that happened to me, the distributor was 180 out. . .
What whacking? Can't never could, until try came along!Here we go!
Tony.M
LOL. I reset the wires in a counterclockwise rotation and she fired right up......When that happened to me, the distributor was 180 out. . .
Thanks Rip. I verified that early on.
Firing order was correct.... for a clockwise rotation...LOL.
I think what scares me most is your familiarity with old Roman sayings!!Well, it's time for the ole guy to own up. After some intense thinking and viewing.... what am I not seeing? It came to me like a rat out of an aqueduct. (As the romans used to say). Firing order was correct.... for a clockwise rotation...LOL. I reset the wires in a counterclockwise rotation and she fired right up......
My advise.... don't get old, or at least remember that you are old. You can all line up and have a kick now......![]()
Don’t feel bad I did that same thing as my cap was marked for a 318 Clockwise and the 383 counter clockwise. My eyes aren’t as good as they used to be. I only saw the one and didn’t think through it.Well, it's time for the ole guy to own up. After some intense thinking and viewing.... what am I not seeing? It came to me like a rat out of an aqueduct. (As the romans used to say). Firing order was correct.... for a clockwise rotation...LOL. I reset the wires in a counterclockwise rotation and she fired right up......
