Hi guys...Just wondering if any of you have had issues like this with your e-brake (cables) in the past and could shed some light on what I need to do. I have a very clean straight practically rust-free 54k original miles 1968 Fury III. I had issues first time out with the car as I bought it just a few weeks ago. Had to get a flatbed to bring the car home because I felt at the time that one or more of the brakes had locked up.
Now that I have it up on jack stands, I have a feeling my main problem was/is the rear passenger side e-brake (I had used the e-brake prior to the last ride home when I had to get a flatbed). I have replaced rear shoes/wheel cylinders/rear brake hose. With it still up on jack stands, I have been testing the e-brake...new shoes in place recently resurfaced drums on and adjusted out reasonably well (may be a little loose at the moment on purpose). Every time I depress the e-brake I can't turn the drums...which of course is good, but when I release the e-brake, the passenger rear always hangs up until I physically move/wiggle the e-brake cable. I've sprayed the whole length of the cable with penetrating oil several times. I've worked it in out from the junction point just in front of the driver rear wheel. I've even removed it from that junction point and brought it out to the passenger side and worked it in/out while it was physically "a straight shot" to the rear passenger brake. While it was in this position, I sprayed penetrating oil down inside the cable too. Both cables seem to be sliding in/out nicely. The passenger side may be a bit tighter and harder to move...but it has the same travel as the driver side. Now...I'm thinking of disassembling the passenger side brakes, removing the whole e-brake cable and submerging it in my parts washer (kerosene) and working in/out by hand...but I hate to if I don't have to. Any other ideas?
Thanks in advance, Bob
