Fitment question re dog dishes and cop car wheels
Ross Wooldridge
Scotland, Ontario, Canada
Hey all,
Will these dog dish caps
...fit these 15 x 7 cop car wheels?
Thanks in advance!
Hey all,
Thanks in advance!
The pictured Dodge hub caps will not fit the pictured police wheels (Chrysler #3766077) without modification. Those hub caps are 10" diameter, but the police wheels use a 9" diameter cap. 10" caps were used through 1967 on larger passenger cars (with 9" on A-body wheels and some 1966-67 C-bodies), then Chrysler switched to the 9" hub caps on all in 1968-1989, including the shown 15"x7" police wheels that were available 1978-1989.
Example of a 9" cap on the police wheels on my Newport:
Interesting - thanks - I was wondering how that could be done. If you come up with a source, please let me know.
Looking at the adaptors you posted - obviously they're a permanent weld on thing, and they don't seem to have what I would feel is the required compression bump and under-seat that would prevent the cap from working its way OFF the nubs once installed. In the original installation on the wheel, the cap has to stretch a tad to go over the bumps, and then relaxes as the cap's rim goes past and under the nub present on the factory rims. That way they're very likely to stay in place. The adaptors are simply compression with no underseat area, and I would think they might permit flex movement that would ultimately result in the cap leaving the wheel.
I was thinking of a spring ring that went inside the larger hub cap and provided the grip around the wheel's hub nubs. It would have to have a gap in it to allow it to expand and contract on installation as described above while still holding on to the oversized cap.
I also like these caps which are 9", I believe, but fek, they're expensive. Wheel Center Caps
I would like to use the proper 66/67 Dodge doggies, but I'd like to get some sort of adaptor ring that allows me to use the wheels in other situations.
@Mike66Chryslers - how did you mount your lovely Chrysler ones?
@Big_John are these what you're referring to?
Wheel Clips
I think they were a ring someone was making that bolted on. I can't find anything on it though. I'll keep looking.
Here's a thread on Moparts I found. 67 Dog Dish Hubcaps on Newer Steel Wheels???? - Moparts Forums I don't care for the epoxy idea on that thread, but the bolts look like a decent idea.
I don't see why the spring clips wouldn't work OK.
OK - so the hub caps in my first picture look like a Dodge version of the "unknown export" Plymouth cap seen the the top row of your picture, and are not the same as the 2768007 cap in the 3rd row of your pic.
The ones I'm inquiring about are smooth on their domes' sides and have a segmented black painted ring on the bottom, and don't have the slight ribbing and single ring as those on your wagon and the 2768007 cap.
Are they the same size, or a different diameter? I guess all I can do is try them and find out.
All great ideas, however, I want to add something to the inside of the cap (if it's oversized), that will allow the wheel not to have any extra additions to it, but will work when I try to put the cap over the hub.
I also want to be able to use the wheels in different ways where I don't want to see modifications to it in the center.
Comparison of the 10" (2460583) 1965-1967 Dodge hub cap and the 9" (#2768007) 1968 B-body and some earlier C-body Dodge hub cap, FYI:
In this picture, the 10" was originally on a 1966 Coronet 440 station wagon with 14" wheels and the 9" was originally on a 1968 Charger with 14" wheels.
What about getting some old 68 later dog dish and spot welding to the inside of your 10" caps. Cut the old cap for correct depth if needed. any heat scars on the out side should polish out. Second thought, I dont think it would be easy getting on and off.
Your idea is one I have been tossing around (seems great minds and fools seldom differ) - if you've time, peruse the articles linked in the above threads. Somebody has done the same thing and epoxied 9" caps inside the 10" caps with claimed success. Regarding your concern that installing and removing the caps might be difficult with welding, the epoxy job should still permits the required flex of the 9" cap edge to clear the wheel nubs as intended/designed. However, I am still leary of the flexing ultimately breaking the bond between the two caps.
However, the more I think about it, it seems that this idea seems to have the most merit in my opinion - allows one to NOT weld/screw/rivet anything to the wheel, and allows the oversized 10" cap to fit with the same kind of grip since inside the cap is the 9" cap doing the job. The flex concern I think would be taken up for the most part by the 9" cap, and would be reduced because the 9" cap is what's supposed to be there in the first place in the wheel's opinion...
Perhaps Panelbond would work. One would have to make sure the epoxy is evenly distributed over the areas where the two caps would be bonded to reduce imbalancing.
