Jerome Erickson
Hi does anyone know where I can find replacement sub frame parts or a good sub frame for my 1966 Newport and the rear leaf spring mounts
Follow. I'm working on a front subframe repair or replace for my 1971 Fury. Hard to find large part.Hi does anyone know where I can find replacement sub frame parts or a good sub frame for my 1966 Newport and the rear leaf spring mounts
Whereabouts in Cheeseland are ya, OP?replacement sub frame...1966 Newport
I do believe soWhereabouts in Cheeseland are ya, OP?
A little help, general C-bodies members: Would the stub frame from a '68 Polara be a match to replace his '66 'port?
I'm in WisconsinWhereabouts in Cheeseland are ya, OP?
Between Wisconsin dells and LacrosseWhereabouts in Cheeseland are ya, OP?
I believe so, also. Maybe we can get a third....I do believe so
I don't understand the trunk lid comment.I believe so, also. Maybe we can get a third....
No dice on rear spring mounting - the trunk lid keeps the driver's down. I haven't really checked the stub as-of yet. It's a 4-door that I will likely pull parts off. Got it cheap and no eng/trans - no real plan to try to revive it.
Will try to look it over closer and get back to you in not too long.
Mark
My less-than-stellar attempt at humor; The driver's spring and shackle are through the trunk floor and up against the inside of the lid.... the spring mounts (where shackles bolt thru) are history on this car. Fully oxygenated iron.I don't understand the trunk lid comment.
I thought he was looking for the mounts that the leaf spring shackles attach to.
I'm just gonna say this... No negativity intended..Hi does anyone know where I can find replacement sub frame parts or a good sub frame for my 1966 Newport and the rear leaf spring mounts
