Green 72 Imp needing lots of work
The lines on the 72' Imperial are so clean and honest, it all works perfectly at that height....begs to be left alone IMHO.
I'm recalling it as a 300 more specifically. With a 4 speed to boot.
Or more likely I'm confusing several cars in one big mish mash...
(Sent using Forum Runner)
Wasn't there a guy many years ago who did that? I remember it because all the mods that were done to get it squeezed in there which really surprised me
I did hear of that story and also a story about 1 of none Chrysler 300 that left the factory with a Hemi.
[h=3]The Chrysler 300 with 440 Hemi (by Curtis Redgap)[/h][TABLE="class: aright"]
[TR]
[TD="bgcolor: #ffffff"] [/TD]
[TD="bgcolor: #d6e9f9"]1970 Street Hemi[/TD]
[TH="bgcolor: #d6e9f9"]10.28:1 compression[/TH]
[/TR]
[TR="bgcolor: #dce4e9"]
[TD]Horsepower (gross)[/TD]
[TH]425 @ 5,000[/TH]
[/TR]
[TD]Torque[/TD]
[TH]490 @ 4,000[/TH]
[/TR]
[TR="bgcolor: #f0f4f6"]
[TD]Carb[/TD]
[TH]Dual 4-barrel Carter[/TH]
[/TR]
[TD]Intake/exhaust duration[/TD]
[TH]284° / 284°[/TH]
[/TR]
[/TABLE]
At one point, serious, and I mean earnestly serious consideration was given to having a Hemi 300 engine. This would have been an exclusive engine just for the Chrysler 300 letter cars. With the introduction of the 413 wedge, it was well documented, thoroughly panned, and argued by a lot of purists that the 392 Hemi turned just as much power, and a lot more power was available but not utilized before the Hemi was tossed out. In all fairness, the 413 Wedge was the better torque producer, along with a hydraulic lifter set up for the valves for less intense maintenance. Until you got past 100 mph, the 413 was marginally faster than the 392 Hemi.
One of the spinoffs from the A990 full racing Hemi program that was built and tested but not produced was the 300 Hemi model engine, meant for the 300 letter series sport sedan cars. 440 ci was obtained by boring the 426 block to 4.32 inch from the 4.25 inches. The 3.75 inch stroke remained the same.
This particular engine was designed to accept the two bolt main bearing cap structure as well as not having to go through the lengthy and expensive bake out heat treatment. It was slated to receive one of the first triple carburetor setups, as well as a 268 degree hydraulic camshaft later to be seen on the 440 Six-Pak cars. It would have used the cast iron heads, so the valve size remained the same with an intended 10.25.1 compression. Horsepower may have been slated for around 455 or more. It was never dynoed, so figures are not available. Of the many 426 Hemi engine variants this was the only one that got two main bearing cap bolts.
Following are some of the specifications from the white paper, written for John Wehrly by Bob Rodger, father of the 300 letter cars, and by product planner Robert Cahill.
Mr. Wehrly had joined Chrysler in 1962 and quickly moved up to become supervisor of racing engine development in 1971. In 1964, Mr. Wehrly was heavy into the Hemi development for the Daytona 500. In 1965, after NASCAR moved to ban the Hemi and Chrysler staged a complete boycott of the NASCAR circuit, Bob Rodger and Bob Cahill, sensing that NASCAR would not ever relent, moved quickly to push the 426 Hemi engine into a regular production model available for the street to anyone with the cash to buy it. The letter follows:
Description: Because of continued requirements for an ultimate performance drag strip and street usage type engine with expanded usage, the following change is the engine lineup has been agreed upon after discussion with the affected areas. Please release a hemispherical combustion chamber engine for "B" Series with the following general characteristics:
  1. Intake manifold to have two four barrel carburetors.
  2. Cylinder block to maintain cross tie bolt bearing caps.
  3. Cast iron exhaust manifold.
  4. Solid lifters are acceptable but not preferred. [Hydraulic lifters were not achieved until the 1970 engine - ed.]
  5. Pistons - forged acceptable and thermally controlled preferred.
  6. Manifolding and camshaft to be designed to give the best highs speed power possible while still maintaining a reasonably drivable vehicle for summer and winter.
  7. Automatic and four speed [manual] transmissions required. 4-speed to receive development priority.
  8. No air conditioning required for "B" series.
  9. Limited warranty is acceptable for the "B" series.
Projected production volume expected is between 5,000 and 7,500 cars, which will take effect in the start of the 1966 production year. This engine to replace the eight barrel wedge requested in Production Planning Letter of 8/5/64.
The above letter was dated January 6, 1965. On January 12, 1965, an engine production letter was issued for the A102 engine. It listed all the items needed to bring the race Hemi engine to specifications for use on the street.Mike Sealey wrote: There is a 1966 Chrysler 300 out there with what appears to be a factory-installed 426 hemi, something most historians say never happened in C-bodies. According to Chrysler historian Jeff Godshall, last minute reconsideration was given to discontinuation of the letter series 300 after the L in 1965. A tentative plan was drawn up for 500 1966 300-M models powered by the 426 hemi, but was withdrawn when marketing research suggested there might be a problem selling even that small a number for the price
It's said it was originally planned to put a Hemi in the 300 Hurst but due to assembly line production at Jefferson this was discarded due to installation problems in regular production. Probably had no sledge hammer at hand, like Hurst for their Hemi Darts.:)
I second that. Was the main flaw with the Hurst that there was no exclusive hipo engine included, should have been at least the 440/6.
If they were going to put it in a 300 thats the car to do it to
1970 Hurst 300[TABLE="class: infobox hproduct, width: 22"]
Hurst 300[TR]
[TD="colspan: 2, align: center"][/TD]
[/TR]
[TR]
[TH="align: left"]Production[/TH]
[TD]1970
501 produced[/TD]
[/TR]
[TR]
[TH="align: left"]Body style[/TH]
[TD="class: category"]2-door coupe
2-door convertible[/TD]
[/TR]
[TR]
[TH="align: left"]Engine[/TH]
[TD]440 ci (7.2L) V8, 375 hp (280 kW)[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission[/TH]
[TD]3-speed Torqueflite 727 automatic[/TD]
[/TR]
[/TABLE]
The 1970 Hurst 300 lacks the single-letter suffix of its forbears and appeared five years after the last Letter Series Chrysler, the 300L. Many automobile historians do not include the Hurst 300 as a Letter Series model. The concept of the car, however, does fit with the Letter Series cars, as it was a high-performance variant of the luxury 300, built with the input of aftermarket parts manufacturer Hurst Performance. Only 501 units are believed to have been built.
The Hurst 300s were all 2-door and shared a white and gold paint scheme similar to the Oldsmobile and Pontiac Hurst models of the day. The scooped hood and trunklid (with a molded spoiler) are both fiberglass. All Hurst 300s had satin tan leather interiors that were straight out of the Imperial and could be had with column- or console-mounted 727 automatics. All came with the 375 hp (280 kW) 440 cu in (7.2 L) 4-barrel TNT V8 engine. Road tests clocked one at 0-60 at 7.1 seconds with the 1/4 mile in 15.9 seconds. "Not bad for a 4,100 lb (1,900 kg) aircraft carrier", they claimed.
Of the 501 units sold, one convertible is documented having been used as a Hurst promotional car and another is believed to have been dealer equipped with a 426 cu in (7.0 L) Hemi, also, a convertible.
[TR]
[/TR]
[TR]
[TD]1970
501 produced[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
I think I have a pic of the "Hemi" Hurst in one of my old mopar action mag's.
A couple are around any of them real
If I recall correctly they have the real one. They did a spread on the owner....who happened to own a 70' Hurst 440, and the HEMI car as well. I'll look and see if I can find it and post the pics. Some people have all the luck.
Rumored............one factory Hemi 1966 300M (prototype) from Detroit for one of the exec's. It was never titled. Other than that, not that I know of. No factory Hemi 1970H's. One dealer installed Hemi 1970H. And maybe a few privately retrofitted.
Mike Sealey wrote: There is a 1966 Chrysler 300 out there with what appears to be a factory-installed 426 hemi, something most historians say never happened in C-bodies. According to Chrysler historian Jeff Godshall, last minute reconsideration was given to discontinuation of the letter series 300 after the L in 1965. A tentative plan was drawn up for 500 1966 300-M models powered by the 426 hemi, but was withdrawn when marketing research suggested there might be a problem selling even that small a number for the price Chrysler would need to charge.The car, which appears to have been a prototype, still exists, and while it is not badged as a 300-M, numerous trim details are different from the garden variety 1966 300 Sport Series. It's known among 300 fans as the "'66 300-M(onkeypuzzle)".
Also as far as I know there was not a single factory installation of the 426 for the Hurst.
Are there any pics of that 66 prototype somewhere ?
