I need to retract my previous post, as the U code 440 HP engines only had 4 clutch discs from the factory. Only V code 440-6 engines and hemis got the 5 clutch packs. I learned that the ring grove in the input shaft for the U code engines signifies a hardened input shaft, and not the 5 clutch disc packs. I researched all the service manuals from 1969 - 1973 to sort all this out. What still confuses me is what D32 vs D34 means for the transmission code? For example, my C bodies with the U code engine have D32 trans codes while my B body 73 Dodge Crestwood wagon has a D34 trans code, but it has the 400-2 bbl engine? And then it also looks like all C body transmissions had large 11 3/4" torque converters, even the V code engines, but B bodies had 10 3/4" converters with the HP engines. All a giant mess.
In any case, all 383-2 or 400-2 bbl engines had 3 discs in their clutches, while the 383-4 and 400-4 and 440 std T code and HP U (4 bbl) code engines had 4 discs and the 440 V (6 bbl) code engines and Hemis had 5 clutch discs.
