For Sale If it's a Mopar, RWD, & a 4 spd, I like it.
commando1
Sebring, Florida
Especially the weird ones.
1976 Dodge Aspen RT factory 4-speed car, trades?
1976 Dodge Aspen RT factory 4-speed car, 318 and 4 speed are out of the car, body good shape all there, only some surface rust, interior all there, asking $1595. obo. or will consider trades, call Bill (no texting please) at 208-440-9956, thanks.
Never seen Another and for that I like it but it's not my cup of tea.
Don't see alot of those as it is But a 4-Speed one is even cooler.That would have the Aluminum case A833, Correct?
Well its only a short distance from Pauls place buy it ship it hot rod it....all it takes is $$$$
Me likey too, although I'm sure they mean OD 4-speed. Good colors.
When I was a children, I used to think those tail lights (and '69/70 Charger tail lights) looked like the stock of a long gun.
I hope my memory didn't scare anyone.
A stroker small block aint no joke, but, you'd need a whole new drive train behind it.
The blue doesn't look nearly as good as it's black counterpart.
Still as OP said, a V8 RWD 3 pedal car equals fun.
Alright, here is my take on this car. 360 magnum with carb and electronic ignition. Old style 833 with pistol grip shiftier, (yes Stan), then after I blew up the 7 1/4 rear I'd install a build 9 1/4 out of a van and put that under the back end.
I'd do a 401 Poly stroker with LS FI. Tremec double OD (Challenger) six speed. Mini tub. No body work (sleeper). 4.56 Ford 9" with Detroit locker. Oh, and maybe a roll cage. :)
Bingo.
Or..........
A 5.7.
Nice car. Had 76 Aspen RT with 4 speed and 6cyl!
Put 318 in it and drove for years. mine was green.
Here's the answer ready built 360V8 bored out to 408CI for only $10750 CDN....
MOPAR 360/408 MAGNUM CRATE ENGINE COMPLETE 465 HP | engine, engine parts | Edmonton | Kijiji
MOPAR 360/408 MAGNUM CRATE ENGINE $10750.00
Muscle Car or Performance Truck Engine
IN STOCK & READY to SHIP (Carb to Pan) NO CORE CHARGE
ENGINE INSTALLATIONS AVAILABLE
TECHNICAL SPECS
Horsepower: 465
Torque: 535 lb/ft
Block: Seasoned OE Magnum Block
Bore/Stroke: 4.040 x 4.000
Displacement: 408 C.I.D.
Crankshaft: Scat Nodular Iron 4.000" Stroke Internally Balanced
Connecting Rods: Scat 4340 Forged I Beam 6.123" ARP 8740 Bolts
Pistons: Forged
Piston Rings: Moly Rings
Compression Ratio: 10.1:1 Compression
Camshaft: OE Hyd. Roller
Camshaft Specifications: 229/233 @050 .520in/.515ex 110LSA
Camshaft Bearings: Installed & Clocked to OEM Position
Cylinder Heads: Edelbrock Performer RPM 58cc/176cc 2.02/1.60
Freeze Plugs: Brass Installed & Sealed
Rocker Arms: Billet Aluminum 1.6 Full Roller
Oil Galley Plugs: Installed & Sealed
Oil Pan: OE 5qt. Center Sump
Engine Weight:430 lbs
Oil : 10W30
Oil Filter: Wix, K&N or Hastings Recommended Per Your Application
Fuel Delivery : Quick Fuel Carburetor 780cfm #HR-780-VS
Intake Manifold : Edelbrock Air Gap #7577
Spark Plugs : Autolite #3923
Spark Plug Gap : .035
Harmonic Balancer/Damper : Professional Products Internally Balanced Weight must be removed #80012
Flex Plate / Flywheel : Stock Internally Balanced (Not Included)
Timing : 34-36 Degrees Total
Water Pump : Aluminum Standard Volume
Firing Order : 1 8 4 3 6 5 7 2
Exhuast : 1 3/4 Headers
Fuel Pump : Holley 110GPH Mechanical #12-360-11
Fuel : 91+ Octane
Ignition : MSD Pro Billet #8388
Automatic Transmission Stall Converter : 2500 plus recommended
For More Info Contact Robert or Brain at The Block Shop Engine Specialists 1979 ltd 780 452-4143 or 780 452 8440
14730 118 Ave Edmonton Alberta
