Lord of the road wheels!!!
furious70
Chitown
Need to clean them up some more. Unfortunately only 1 good center cap and 4-5 rings. Rims are nice though.
"Hoarder", as some of my Mopar associates might say. LOL
The challenge with these wheels is removing the rust from the rim whilst not damaging the chrome center section....
On mine, I think I am thinking about making a special container for soaking them in Evapo-rust, with wheels oriented vertically, so that the chemical only covers the rim. If the Chrome comes into contact with the chemical, it will fall out into solution and eventually deposit copper onto the bare steel areas (from experience). This despite Evapo-rust not being an acid...
I'll verify tomorrow but I thought I remembered seeing one stamped 6.5", to make it more complicated
IIRC, they were all 15x6s, except for the "bent-bar" LeBarons of 1977, which were 15x7?
ok all of mine are 6"
at least 3 part numbers
3580467 (looks to be the same as below)
3580067 (72-74 B/C body)
and another I can't identify yet seems to end in 471
I used cleaning vinegar to remove the rust from the road wheels i am putting on my wagon. I soaked absorbable puppy pads then wrapped the wheel with them and let them sit for about a week then was able to use a wire brush green scotch pads to remove all the residue.
I believe they are the later style 74-78 as the wheels came from a 77 New Yorker. The center cap part # is 3699011
3699461 is listed as b/c 15x6.5 rallye class one.
W23s are listed as "Class II, 16-Slot Road Wheels". There WAS a 15x6.5 Rallye wheel that was optional on the mid-'70s Charger SE. They look like the 14" Rallye wheels. I bought a set of them out of a local salvage yard and they are now on my '70 DH43 as the OEM W-23s "rest".
yes, I've had those too. Galen's book does call the c body ones styled wheel I guess. but lists the 6.5" for C's as well - maybe a mistake for the B body Fury vs Gran Fury?
78 NYB Salons had as standard had black painted 15x7 road wheels under the "aluminum fascia basket" and trim rings.
these wheels were also available as an option on 78 Dodge Magnum XEs, Monacos and Plymouth Furys but not available on other Chryslers
The 15x7 version of the road wheel debuted in 78 (used behind the aluminum fascia road wheels above) and then used til 81 on M bodies (chrome again and with plastic inserts that were painted to match the colour of the car.
There are a few ok center bodies, only 2 of the splined top cap.
I may sell singles to those who have asked, but it's an even 12 right now.
I'm planning on light restoring the best 4 for resale as a set. Probably sell some others undone for those who like to restore themselves.
What's the right gray/argent paint for the center?
I've had good luck soaking wheels in vinegar, I used a cut-down plastic barrel (got from work) and then a 1500w $40 heater from Amazon.
Depending on barrel height you can do multiple wheels at once.
Heat really accelerates vinegar's work. I let them soak for 1-2 days, keeping the heater on only in the evenings when I was home.
It did not seem to affect the chrome, but it did weaken the existing silver paint.
And totally removes other paint.
Amazon product ASIN B07S95WHXB
