78Brougham
"Chump"
Now convert to CDN $$.....$108000 is the new reality on a Megacab Dually 4x4 Limited
Isn't that what a whole city block sells for in Detroit?
Maybe, but you can't drive that.Isn't that what a whole city block sells for in Detroit?
Dealer time.
On my Durango I can also turn on the heated steering wheel through the U- Connect screen. Maybe Bob try that?I have a question about my 2018 Gen 4 Ram.
I know this is a trivial issue.....
The heated steering wheel quit working on my Ram. I'm pretty sure I know how to operate it. You push the heated steering wheel button and its suppose to stay on for a 80 minute cycle. Well mine shuts off after a count of one second. Any ideas besides take it back to the dealer? It's a 2018 so it's a warranty issue.
What do you mean, also? That's the only way I have.On my Durango I can also turn on the heated steering wheel through the U- Connect screen. Maybe Bob try that?
Well Peter to be honest I've never had to use it and probably never will. I only found out I even had it a couple of weeks ago when I was playing around with the display.
I hope you at least use the ventilated seats then.Well Peter to be honest I've never had to use it and probably never will. I only found out I even had it a couple of weeks ago when I was playing around with the display.
The cars are programmed to turn on the heated seat (and wheel if so equipped) when the car is started at a temperature of 40°F or below.
The trucks up to '18 for sure have 3 buttons. Two for the seats and one for the wheel.
I can set it for all starts, or just remote starts.The cars are programmed to turn on the heated seat (and wheel if so equipped) when the car is started at a temperature of 40°F or below.
I have found but one button to turn on the heated wheel ('19 RAM-DT). And it lives in the Uconnect.
I do use the A/C quite often!I hope you at least use the ventilated seats then.
Wait, you have a hard button for the heated wheel?!?
One of my various gripes right now...
My 18 has the multiple accessories bank of switches so I lose the hard switch for heated wheel and seats and it is only in the 8.4.
My 15 had the hard switches
