Would it be good idea to use 451 heads with the extra cooling margin. Seems that would be a plus. Weight doesn't matter 68 300 vert! is a barge anyway.
I was always told that all big blocks heads were virtually the same with the exception of the 63 300J heads which are the same as 67 HP heads. These are only heads with 1.74 exhaust AND closed chamber.What's your opinion on heads. I just want some low end ooomph!
Thanks,
Tom
You should not run into cooling issues with any heads in a passenger vehicle.
The first step with a compression ratio is to settle on a set of heads and then check the chamber volume... I would not attempt to make a quench engine with iron, closed chamber heads, if you plan on running pump gas.
When you know what chamber CCs you are dealing with, then choose the correct piston by the compression height and valve relief volume that get you around 9.5 to 1 for pump gas with iron heads and 10.5 to 1 with aluminum heads.
ALWAYS change your compression with the piston and to a small degree the head gaskets... The
pistons along with the head gaskets are the expendable parts, not the heads, and certainly not the block.
Squaring up or checking the block deck however is a good idea, and of course a small degree of milling is fine, but larger amounts will mess up your valve-train geometry and can also screw up your preload in your lifters if you do not have adjustable rockers or pushrods.
Compression height on pistons is figured considering a 10.72" deck height on a 440.
If you want to confirm your compression ratio before you send for pistons you can PM me so I notice the request and I can show you the math/numbers and how to figure it before you invest in parts.
If you insist on cheaper pistons like Speed Pro/Sealed Power/Federal Mogul be sure to get forged and NOT cast pistons, and let your machinist know that they are forged as your skirt clearance will vary depending on the piston material and use.
