yellowkeeble
HELP!!! On my way to work the other day , approximately a 25 mile ride one way, my 67 Fury III just quit on me. It's a newly rebuilt 440 engine with Pertonix ignition parts, Ignitor III module and Flame Thrower II coil. The car will not start and I'm stumped, hopefull someone can offer some suggestions.
What I've done so far:
That's a gist of the work done so far. I don't want to just by parts and replace until I accurately diagnose the problem. Any help would be appreciated.
- Checked that I'm getting 12v to the coil. Yes I am.
- I'm getting spark from the coil. (Grounded off a plug from the coil to the block)
- I am NOT getting spark at the cylinder. (Again, grounded off a plug to the block)
- Bypassed the 12v and ground to the coil by going directly from teh battery. Still does not start. ( Trying to determine if there is an elctrical problem elsewhere that is grounding off and I'm losing power.)
- Replaced the ignition module (ignitor III) in teh distributor. Still will not start.
- Checked for fuel delivery. Yes, I'm getting gas at the carb and plugs were wet with fuel. Dried the plugs and still no start.
- Checked rotor and cap for damage. No damage identified.
- Distributor was pulled out and inspected with no damage found.
