badvs3vil
Hello, I have a 73 Newport Custom
I just installed a BBB rebuilt gearbox and so far its been great. So now everything except the lower control arms and torsion bars have been replaced. Which leads me to my issue.
After I got the new gearbox in and also the moog offset upper control arm bushings, I went and got an alignment. I had set everything to max caster before going in. Both sides had +5% caster! However, when they went to align it, they said the drivers side could not get any positive caster and keep the cambre within spec, as soon as they try, it goes way off. To add on top of that, currently the car pulls a little to the left. Also after a turning, even a little, to the left, it stays there and does not return to center.
My question to the ones that are smarter then I is this. Could my issue actually be my drivers side torsion bar? If you look in the top picture you will see the Torsion Set Screws. The drivers side (right side in the pic) you can see its screwed in pretty far in order to get the car even. The second pic shows how even she is right now. Could that be my issue?
