70NewY’ER
Hello all. I have a '68 Newport with drum brakes all around. 2 3/4" up front and 2 1/2" in the rear. I had the brakes redone about a year ago. New master, wheel cylinders, hoses, shoes, hardware, wheel bearings, etc. I noticed that whenever I would take the car out for a drive, the rear drums got wayyy too hot (about 300 degrees F. on both). So, I figured maybe the problem was related to the proportioning valve, so I found an NOS P.V. on Hiltop Auto Parts and replaced the old one. Brakes still got hot in the rear. After that I thought it could be the drums and shoes, so I replaced them. Shoes are from Powerstop, and the drums are from Raybestos. Still very hot. The wheel bearings don't seem to be getting hot either. The major heat is coming from the shoes and the drums. I thought of everything and can't seem to figure out the problem. Not even my local mechanic can figure it out. Could the master cylinder be absorbing some engine heat and causing problems? Bent axle and/or flange? I have the car registered for the upcoming Chryslers at Carlisle event and I'd like to get this sorted out before going. I'm not an expert so any help on the matter would be greatly appreciated. Thank you!!
