Old man Utah
Hi guys, I've a problem that I'm sure some of you have encountered and dealt with.
On my 75 Town and Country the drivers side power window is slipping on either the regulator teeth or the motor drive teeth and need to fix it. On earlier C bodies I've always managed to get the glass and motor out quite easily but these are more difficult.
When trying to unscrew the two screws that go through the lift channel and the glass, the flat circular retaining nuts on the back of the glass are turning with the screw. I've tried to get grips on them to stop them turning but being so flat its almost impossible and you have to be careful not to break the glass. Would appreciate any thoughts on this. Thank you.
