There are 5 different case numbers for the 8 3/4 housing....985, 657, 741, 742, and 489....the last 3 being the most common. The first 3 use the smallest diameter pinion shaft and their related bearings and seals. The 742 case uses the medium size pinion shaft, and the 489 the largest. The first 4 cases have a fixed spacer between the pinion bearings and allow you to swap flanges without having to worry about bearing preload. The 489 case uses a crush sleeve where you have to make sure the preload is the same if you swap flanges. That takes and inch/pound torque wrench to accomplish that along with the procedure involved to measure the existing preload. I've seen at least 6 different pinion flanges used depending on year and model of Mopar. Most are bolt and strap versions and are either for the 7620 (2 1/8") or the 7690 (2 5/8") u-joints. There are also U-bolt and velocity joint versions on C-bodies as well as some on trucks/vans. As I mentioned, you can swap them out for the ones you need once you determine case number and the number of splines on the pinion shaft. On the first 4 cases that's fairly easy (if you have an inpact gun). Zip off the nut and count them. The 489 can be converted to a fixed spacer these days, but, you have to reset up the pinion depth just as you would if you put in new gears. A recommended procedure if you want max performance or even if you change gears. It just makes life easier down the road should you need to pull the flange again for any reason. There are some side gear differences on the real early housings in the 50's, and also the oddball '65 B-body 6cyl. 3rd member. It's not an 8 3/4, it's actually an 8 1/4 3rd member. It looks very similar to an 8 3/4, but, it is different and not one for performance use even though it has an interesting 3.31 gear option. It might be fine for the highway or a grocery getter, but, it has lots of unique parts that might be a pain to find if needed. Another note I've run across is the real early 3rd member housings and pinion snubber holes. Some didn't have them drilled. Dealing with the different axle end play spacers usually isn't a big issue, but, sometimes it is when swapping '64 and older, with '65 and newer. Putting an older 3rd member into a '65 up housing with adjustable axle bearing retainers usually has enough adjustment on them to get them within specs, but, not always. Going the other way is more difficult with the need for various and sometimes lots of shims. Same goes with the sure grip versions. If you have a '66 Fury with a 741 case and a typical bolt and strap pinion flange, and you want to get another 3rd member, I'd stick with finding a '65-up 741, 742, or 489 with the gear and flange you want, and based on the horsepower you plan to have. The sure grip carriers can be swapped on any of those housings. Personally, I prefer the clutch type version as it's easier and cheaper to rebuild if worn out. There are some aftermarket ones too that are a good choice for drag racing. Oh, and your knock on the end play adjustment design, I think it's wonderful. One adjust to do the whole job, and it takes just a few minutes to do. Once set up and the new tapered roller bearings installed and properly greased, you can run that thing for hundreds of thousands of miles without a worry. They'll hold up to the most punishing side thrusts you'll see. Ball bear rear axles, well, just ask the FoMoCo owners how those hold up over that length of time and punishment. Chevy C-clip and bearings run right on the axle shaft? Please....The "green" bearings are a pretty good ball bearing though i have to admit, and one I would use of I couldn't get the end play within specs without major re-engineering.
