rear end ID help
Mike McGuire
new hampshire
Hello Mopar fans,
First visit on the rear end of the 55 Windsor/300 project.
I understand most were 8 1/4 rear ends, but unsure of myself here,
as it resembles the 8 3/4 a bit, and does not match the google results for 8 1/4 rear end.
Thanks,
Mike
Looks like an 8 3/4 rear, perhaps it was retrofitted? One way to check is to look for a casting date on the housing. I don't know if 55s ever got an 8 3/4, but others here will. MyMopar dot com says they were introduced in 1957... so, it's likely a retrofit.
In 1965, the design of how the axles were held in place in 8 3/4 rears was changed to permit easier servicing. A sure fire way to know if it's a later rear end is to see if you need a puller to remove the drums. If if you don't, then the assembly was made no earlier than late 64 for use in 65, or later vehicles. If it needs a puller to remove drums to service the axles, then it's a 57-64 design.
All in all, I think it's a retrofit axle assembly though.
What vehicle is that? Interesting shock plates are on upside down and shocks in front of axle.
It looks like and 8 3/4. Count the nuts and studs holding it in. Are there 10 or 11?
The yoke looks like a U-bolt type, but it has Straps nuts and studs.
413,
It is a 1955 Windsor. However, it was purchased as an abandoned project. The rear springs have been replaced w/ 300 springs. Perhaps the shop that did that flipped the shock plates. I will check with Chrysler 300 Club resource on that & my shop manual. Thanks for catching that. I'll report back on both items.
Thanks,
Mike
What type of axles? Look at the ends amd the hubs, do they have the nut and cotter pins? Or flat ends?
