Rebuilding a 440
nadocor66
Lansdale, PA
Thanks for the help so far. Engine and transmission are a 75' model year C body 440. When rebuilding this engine what are improvements that I can make to increase power/torque without sacrificing drivability? Car has AC and a 3:21 open rear. Eventually plan on converting over to FI.
Port and polishing?
Head/valve train work?
Camshaft?
Oil pump?
Block hardware. head bolts, expansion plugs?
Best gaskets?
Carb?
Cooling system?
Any input and or expertise is greatly appreciated in advance.
Thank you, Ray
Increase your compression ratio by installing taller deck height pistons. The 906 cyl heads work well so simple valve job W/ new springs will serve you well. Use a Melling SP11 camshaft kit. A Melling high pressure pump. For a carb w/ good reliability go w/ a Edelbrock 1411 rated at 750 cfm. With a Recurved the dist. this will give you a very good reliable 440.
