Rim ID...Mopar, Buick, or......??
Scoopy G
Tampa
I have these rims in my shop, and I'm not sure if they are Mopar or GM or whatever. I figured there would be some keen observers in the group who would know.
Rim A I think is a 14" Mopar rim. Lugs are 2-11/16" center-to-center.
Rim B might be a Buick 15" rim. Lugs are about 2-7/8" center-to-center.
I can't find any stampings on the rims that indicate GM or Pentastar or even Ford. Any advice will be appreciated.
Rim B" isn't looking too good. What happened to the center of it? Not sure what that would fit but I agree with Owen11x, about "A". It looks like a Mopar rim.
Thank you Gentlemen, I knew there would be expert advice out there.
The photos of the B rim might look like the center of it is wonky (kinda hexagonal), but it doesn't seem to be as a result of anything wrong....it looks like a factory thing.
As we speak, I need to pull the drums on the '63 Riviera to inspect the brakes after 4 years, so I'll try to fit that B rim on the car, and see if the rim is screwed up.
Thanks again Gents, as always I appreciate you help.
Kelsey Hays was the original supplier to GM for years, not sure about Mopar. There should a PN stamped in the inside hoop. Try googling Kelsey Hays and the PN. That may get you somewhere.
Rim A looks like it could be an Aspen/Volare rim that has clearance for disc brakes.
I just looked at a 68-newer drum-brake rim in the basement, and it is noticeably different from the one pictured.
