So when I tested the window washer on my Fury, I found it was dead. Had a look around and found the ground screw for the washer assembly was missing, and a piece of electrical tape wound around the tab it would go through.
I put a screw in and .... the key wasn't even in the ignition and the washer motor started spraying water all over the floor, which is where someone pointed the tubes they'd unhooked from the jets....
There's 12v on the positive side of that pump, at all times. Dead short to the battery. I removed both wires from the washer switch (massive PITA) and still a dead short to the battery. Next I pulled the bulkhead connector inside the engine bay - that finally removed the 12v supply to the pump, and I checked that the pump was connected to the correct pin on the bulkhead as per the wiring diagram, which it is. That pin is still a dead short to the battery.
So I can only assume there's an insulation short back there behind the dash somewhere, or someone has made a really dumb wiring error. I can't really tell if the correct wires are on the few switches I could see as the colours are too dark to tell apart in some cases. I can see some of the wiring has been messed with before, but it's difficult to really access anything - great big metal panel in the way. I put my shoulder out for a week trying to get a good view from the footwell.
How can I remove the dash, or that metal frame, or at least the dash plastics so that I can get some more space or at least some more light in there? I've worked on old wiring before but I've never come across a huge metal bin blocking pretty much all access to things. I couldn't see at the time, but how do you access the inner bulkhead connectors?
Bonus points if I can get some space and leave the car in a state where it can be started up to move within the storage unit still!
