67Monaco
Moser Engineering 1/2x20x1.75" wheel stud fit the 67 disc brake hub. Maybe not perfectly but within +.009". I needed them because I really never felt the lug nuts had enough threads in them with the AR wheels and a 1/4" spacer. Space was needed to clear the caliper. Honestly I could get away with 1/8" but 1/4" was what I could find when I bought the wheels.
Not having a press I had to put on my thinking cap. Normally same sized splines I'd be able to line up and pull back in to the hub or axle flange with the wheel and lug nut. However these are slightly over sized, ever so slight. Actually on paper the should should be exactly the same with just courser splines. Anywho. I solved the problem of having to press fit with e ball joint press. Pretty easy to do. I'll tackle the passenger side tomorrow.
