My experience no you do not need the vent the dsistributor should have drain holes in the bottom if they are clean you are good. But there are MANY opinions on this also. But millions of cars ran fine without the vents and still do.
I always wondered - do we need to have the OEM style distributor cap with the vent? Many replacements do not have it. Can moisture accumulate without the vent?
If you have an inspection camera that you can use a quick look into the fuel pump opening will tell you if there’s a problem with the cam lobePulled the fuel pump and pushrod out and discovered that it's under 3". We ordered a new one and it's on it's way. Do you think the cam wawadamaged as well? See attached photos. One being our engie bay and the other being the pushrod.
Remember its going to be harder to install the fuel pump now.
Sweet! It will run and drive like a new car now! Hopefully you got a good unit that has been hardened properly as a replacement. Where did you get it?
A link to it?Summit Racing
I changed the oil as insurance, since that's where the lost metal from the rod went, and put a new(er used) pushrod in. I applied a liberal coating of moly assembly lube to the replacement rod when installing. I also plumbed a small fuel gauge inline in the hard line going to the carb, so I'd be able to diagnose if this happened again. It's been several years and no problems yet.I bet the cam is fine because it's barely touching. Mine was fine if that makes you feel any better, pretty certain Matt didn't damage his cam either.
