saylor
o wise and venerable forum!
muh horn quit and I have no idea why. so I was thinking, if I go to the horn relay and start there it may get me in the correct direction at least.
test1: from the relay, if I ground the horn trigger pin, horns should go off.
test2: from the relay, if I cross +in pin to the horns-out pin, horns should go off.
test3: from BATT to horns direct. horns should go off.
if test1 fails, my issue is the relay or horn buttons @ wheel
if test2 fails my issue is the relay
if test3 fails my horns are fried or bad ground at the horns
what else can I do to get more specific testing to better prove this out?
is the turn signal cam/assy involved with the horn (inside the steering column?) I lose track of the horn wire @ turn signal assy in the FSM wiring diagram...
I have a 3spoke Plymouth steering wheel that I do not find in the FSM, I think its early/67? ive never seen another fury with one. non tilt/telescope. automatic. how can one test the buttons/connections here? Only 1 of the 3 spokes really ever fired the horn since I've had the car, the other 2 spokes don't really function like they should.
thanks!
- Saylor
thanks!
- Saylor
