1964 Imperial finding drum brakes
64Imperial
Cumberland md
Hey I'm redoing my brakes on my 64 and I have no clue where to start with the rear drums... I'm converting the front to disk, but I honestly need to look for a new set of rear drums. Anyone know of drums that are currently being made and will fit?
AFAIK, there is no reproduction made.
Either you find good used ones, or you can try to have them turned (if that's the problem).
O.K.
I'm assuming we're talking Key Way Drums here.
If you are going to the Expense & Work of Fitting Front Discs Why not slip in a Later Slip-Drum Diff as Well.
Many Years ago I fitted a 8.75 out of a 66 "B" Body under my 59 Custom Royal.
The "11" Inch Backing Plates, Drums Etc. from a "C" Body 8.75 Fitted right on.
The Supply of Later "C" 11 Inch Drums I would assume in the States would be Plentiful.
You just have to choose 2" or 2.5" Backing Plate / Drum Combinations.
As I remember I had to have the Spring Saddles Re-Located.
Only My Suggestion, But it Might be Worth Investigating.
Regards Tony.M
I have a handful of the remaining 1963 - 1964 Chrysler *** N.O.S. !!!! ***
11" x 3" Rear Keyway Hub & Drum Assemblies-- but since they are 5 x 4 1/2" bolt pattern -- they do the Newports, New Yorkers, and 300s ONLY.....
The Imperial --- being 5 x 5 --- just simply DO NOT EXIST in the New and N.O.S. worlds....
The Imperials, are sadly, strictly in the Used world.....
Might some non-Chrysler 5x5 drums be modified to fit?
Just curious,
Thanks everyone for the suggestions! And I'm considering modifying a new drum from rockauto for a chrysler around the 60s. I know they had the same 11×3 drum, just different bolt diameter! Hey I'm willing to spend $20 on an experiment lol
Murray Park might have some good used drums.
Www.cbodies.com
I have some on a 73k mile 64. They are in unknown condition. I do not have a puller that will fit 5.5 pattern at this time. I have freind who says I can borrow his!
$65 ea. + shipping. If they are good? Another option may be to switch to 66 imperial rearend with slip on drums?
