TNT440
Is the light bulb socket on 66 300 tail light a friction fit into the housing? Or do you have to twist them to get them out? Don't want to break anything. Thanks
Thanks, it's not the actual bulb I'm talking about, it is the socket into the tail light housing.Push in and twist. If they have been in there for awhile they may not come out easily. If you aren't careful you will break the bulb and possibly cut yourself.
Thanks, they are snug, so I didn't want to start pulling on it if it has to be turned.If they are like my '65, they will just pull straight out from the inside of the trunk. No turning.
A little bit of wiggling helps.Thanks, they are snug, so I didn't want to start pulling on it if it has to be turned.
