My three 67 Polaras
I just finished my rebuild using Moog parts, and if I recall they did not include the sleeves so I reused mine. If you have trouble finding steel locally, I have used speedymetals and also discountsteel online to order steel tubing material. If you use DOM there will be no seam on the inside to cause problems going on. Otherwise it is necessary to order a reamer from ebay or Mcmaster carr or yardstore.com to clean up an HREW tube. The stuff I have seen in the overpriced steel racks at hardware store chains is all HREW.
