1968 300, any way to have engine temp lights AND a gauge?
You can add another sending unit and mount an aftermarket guage under the dash
It's that simple.
There is a second hole by the idiot light sending unit to place another temperature gauge sending unit on the front of the engine.
Really? I didn't realize -- that's cool. I knew there was a second hole for the oil pressure but not for the water. Thanks!
Yes. Its a little pipe plug similar to the plug used for the oil pressure sender you use for an oil pressure gauge. Its smaller.
What temperatures do the idiot lights actually engage at? I’ve always assumed if it got to the point where the hot light came on - you’re screwed anyway.
I don't know. . . Its most likely the temperature where 50/50 anti-freeze coolant boils. If you shut her down when you see the light, yer probably OK.
Just be aware of one thing: right now, with just idiot lights, you will drive your car and enjoy it, without any thought to the heat in the motor as long as the red one is not lit. But, once you install the gauge, you will always be aware of the temp and wondering if you're too hot. It's a great way to destroy a nice drive.
Just my opinion....
This is what you are looking for
This is a fantastic post, as I was just considering doing the same thing. The PO installed a decent "Day Two" underdash three-gage pod using the normal sending unit location for his gage, and it works good. But I'd like to have the groovy Cool and Hot lights, too. I'm thrilled to learn that there's another hole available, as I was thinking of using the similar block drain plug hole(s) or making a fitting and tapping into the heater hose.
Just my opinion....
Here's an idea . . .
Get a "heat gun" and use it to check the temperature at the thermostat housing as the "COLD" light goes out. Probably in the neighborhood of 175 degrees F or so? The "HOT" light will probably trigger at about 240 degrees F, which is a bit under the boing point of a 50/50 coolant mixture with a 15lb radiator cap (which I believe is 260 degrees F or so?).
By observations going back into the middle '60s on our '66 Newport and other similar factory a/c Chryslers (and from techs who worked on them), if the factory cooling system is clean and has a good radiator cap, you'll never see the "HOT" light illuminate unless . . . there is a leak and part of the coolant has leaked out, a failing water pump, a failed thermostat, or a failed fan clutch. Now that the cars are now much older, these "HOT" modes might also include a cooing system with a lot of "accumulation" in the water jackets that needs new freeze plugs and a good flush when they are removed for replacement.
A more "normal" time to see the "HOT" light would be after a restart in the summer HOT weather, momentarily when the engine starts after sitting a while after driving. It should go out as soon as the engine has run a minute or less, typically.
As noted, it's pretty easy to add a temp sensor for an accessory gauge. There are always advantages to having a gauge to monitor, but if everything's in good working order, the lights can do just fine.
It's in the FSM on what temperatures turns off the COLD light.
I can't recall if the FSM states specifically when the HOT light comes on.
Great post, thanks for the info, and especially the pics! I had some overheating issues over the summer - the hot light came on when I pulled off the interstate to get gas when I was returning from the Mopar Nationals in Columbus. The light went off when I revved up the engine so it seemed like it was a problem with coolant flow. I've flushed everything and things seem to be better (no hot light) but I'd like to know the temp to get a better feel for how the cooling system is working. That's on my list in the spring when the Newport comes out of storage.
There it is! My "Hot" light did come on in my Newport.
My son and I had driven to the "American Graffiti" show in Modesto in 2007. It was a warm day driving home so I put the top up and turned the AC on. About an hour from Bakersfield it came on. I turned off the AC and it went off. About 15 minutes later I turned it back on and everything repeated. Once I made it to the Bake the hot light stayed on, even with the AC off. The next weekend I pulled the radiator and had a third row added to it. Have never had the problem again.
American Grafitti Show, Modesto, 2007. If you've never been, it's a great show!
Indeed, you can buy a Dakota Digital guage that has the input screwed into those extra holes mentioned and it fits very nicely into the ash tray in my 1966 300. Since the ashtray isn't used any more you can just leave it shut unless you are concerned. It is very accurate and you can quickly learn how much speed, load, altitude and outside temp affects the engine temp.
Reach out to larrywjett@gmail.com if you want photos and details. I have put the guage in every Mopar I ever had because it is spot on correct. No need to add stuff under the dash.
