1968 Town and Country Turn Signal and Emergency Flasher
Julesva5
Leesburg, VA
All - super helpful forum here - can someone post a pic as to where the flasher is located on the 68 Town and Country? I believe I need to replace the turn signal and emergency flashers. Also for the turn signal, mine is flashing very slow on RHS but fast on LHS. Are there two flashers that control these (one each side)? Thanks much!
Mark
That's more likely a ground problem or even a bulb or two out. It's not a flasher problem.
Only one flasher for turn signals.
Generally speaking, flashers either work or they don't work. They either flash the signals or they don't.
What can affect them is bulbs being out, LED installs etc. Usually though, it comes down to bad grounds on either the front or rear (usually rear) turn signals. Best way to check for bad grounds is a long wire with a couple alligator clips on the end. Clip one end to a good ground and touch or clip the other to the turn signal housing(s) to see if it improves.
On the 68 Chryslers the turn signal flasher is on the left side back of ashtray frame.
Hazard flasher on the right of it.
