cm23uoc
- Joined
- Feb 13, 2011
- Messages
- 8,368
- Reaction score
- 3,448
Hard to tell by the photo but if you encounter any leaded seams and don't plan to use lead to fix them, you will need to remove the existing lead. Plastic filler (Bondo here) don't adhere to lead.Is this messy butchering job on the roof seam factory work?
WTF. Is that a bank vault behind there ?
The normal paint is really easy to remove, but the finger thick bondo eats up the cookies pretty quick. But I made good progress today, at least until I had to learn that the protective cover on an angle grinder is there for a reason... The cut is, lets say bad to the bone... -_-
And I need some of these trim clips. Are they available somewhere?
Thanks for not showing a pic of your finger!
