commando1
Why are you awake, Jeff?
I still operate better in the am... OR... I'm an idiot... decide for yourself.Why are you awake, Jeff?![]()
I still operate better in the am... OR... I'm an idiot... decide for yourself.![]()
Hello Julian!Which one would you use and why? What are the Pros and Cons of each one?
Thanks for your opinion on that! You're probably right. I guess that's the way to go!Same thing different design. The 72 looks simpler and was probably changed to make it cheaper... and in this rare case probably better. Why do I say this you might ask????
Because the 69 version, if not perfectly set up might cause metal to metal contact.... and squeak.
I also like that the rubber is better encapsulated and protected in the ‘72 version. It also more positively connects the leaf springs to the axle. It also hast the advantage of not relying solely on the crush of the rubber through compression and shear (under lateral loads) as well as tension on the U-bolts. On the ‘72 the U-bolt work primarily in tension.... as they should.... and the upper heavy steel cover and base take all the lateral loads.
In my opinion.
Javier
Hey Mika, I wa only able to find universal rubber pads. The only correctly shaped I found are Poly Urethane.Hello Julian!
I think that 73 T&C is right , -72 version seems better but both will work for sure. Did you find new rubber parts for them ( -69 or -72 or both?) Or do you need to do them yourself?
Regards,
Mika
I did ask for your opinion (and everyone else) and I appreciate it!Sorry Julian. You didn’t ask for my opinion. I’ll try to stick to answering questions and enjoying your terrific progress. You are doing a magnificent job!
