CanCritter
Really impressed with your work, Critter. Tell me, did you power wash the under carriage before you hit it with the Rust Bullet? It looks like it was pretty clean before you did it.
4-5 hrs blastin and vehicle was in the air for easy access...200Degrees + hot water and hold on tight spray blast 1000psi....Hotsy Hotsy Model 680SS Hot Water Pressure Washer
….any grease or dirt on that car is long gone...any lose undercoating long gone along with not lose in areas...then hit it up good with rust bullet cpl weeks later and topped it off with rubberized undercoating...that babys bottom is sealed good as well as a 2k primer coating in car itself...
