SOLD 1971 Chrysler 300 2dr, factory U-code, project or parts car
gts95
1971 Chrysler 300 2dr. Fairly loaded car including the E86 440. Picture of fender tag attached. Car is rough. It's an Arkansas car so doesn't have rust from but salt, but rather shoddy bodywork and sitting in humidity. Somebody replaced the vinyl top in the mid-90s and probably did not prep the roof right. It has rust around the front windshield chanel that will need metal work. Top has some pitting. Front and rear glass were broken by previous owner. Car had heads removed and they were refreshed which is why they are painted blue, but I do see Hemi Orange on other parts. Intake, carb and HP exhaust manifolds are in the trunk. Original dual snorkel air cleaner is missing comes with what looks like a late sixties air cleaner?
Seats are nice but look like they may have been dyed at some point. I did not crawl under it to see if it's matching numbers but it is a "G" 440 and is also stamped HP on the ID pad on top. Motor is a complete unknown so count on rebuilding it.
It will need total restoration!
$1800. Located in DFW, Texas area.
Does have Arkansas title that is open on the back.
I can take more pictures if needed.
Thank you for posting CS23U1C174544 -- how rusty is the bulkhead?
Thank you for posting this. I’m afraid it’s a parts car only. IMHO the body is too far gone, it would need so much work it would make no sense. (I could use those Road Wheel Center Caps.)
