67newport
not mine
1971 Dodge Polara for sale( Facebook only listed Monaco). Has 360 cu in with 2 barrel. Runs drives, has a power steering leak and needs a thermostat, I have the thermostat and will try to replace it soon. Factory ac car but ac non functional, heat is functional. I have replaced the pinion seal and differential fluid. Front tires are fairly new, rear tires are older but good condition with like new tread. I believe the 22k miles are original ,but , do not know this for certain. I Daily drove this car for months, if you have tags you can drive it home. This is not a show piece, it’s a driver quality car. With some minor maintenance and a coat of paint it could easily be turned into a show worthy car. If I think of anything else I will add it later. It’s a great car, just needs time that I don’t have right now
1971 Dodge Monaco
1971 Dodge Polara for sale( Facebook only listed Monaco). Has 360 cu in with 2 barrel. Runs drives, has a power steering leak and needs a thermostat, I have the thermostat and will try to replace it...
www.facebook.com
