3.23s Swap
67valiant 100
NY
picked up a 3.23 geared 742 case for $50 bucks at Carlisle :yaayy: this weekend to replace the constant overdrive like 2.76s in the convertible. Has anyone else done this swap? How'd they like the gear ratio change? Figured I can rebuild the 489 case thats coming out with some track friendly 4.10 spool for the other cars.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Going from 2.76 to 3.23 will result in a definite seat of the pants feel and increase in acceleration. If the goal is quicker pick up w/o going to low while still keeping the RPMs under control at hwy or interstate speed then it's a good swap.
Nice find...
Don't forget the speedo is going to be way off. You're going to need a new speedo txsm plastic gear to correct the speed.
Are the u-joints the same size between the 742 case and the 489? I know the spline count is different on the yoke
It depends on the options/motor, I have two dodge chargers and the 383 car has smaller width yoke than the other car which has a 440. so while the drive shafts are the same length for the same gearbox and such they are not interchangeable.
Howdy NAPA has the U-joint for offset yokes the part number is NAPA 347 I've used this U-joint many times
I swapped a 3:23 sure grip into my 69 300, replacing the 2:92. Big improvement. Gas mileage suffered just a little. I found a speedo pinion gear on ebay, I think it is a 21 tooth "green". There are charts in the parts book you can reference for that. U joint was a direct fit.
The 3:23 has been my favorite all around ratio for several 440 auto cars I have owned, both B & C bodys.
