TxDon
I took the last couple of days and worked on the front end, replaced the shocks and all of the sway bar rubber. I was happy to see that there were no rusty bolts and everything came off easy. The sway bar had been done before as both the frame supports and end links were the bolt-on type. Pretty easy install, although I forgot and tightened up one side then was surprised when the other side wouldn't fit! The shocks looked fairly new but one had no gas in it and squeaked when the rod was moved, definitely shot. I took it for a ride today and there is a big improvement, no more bottoming and porpoiseing and no more tire squeal on turns. The rear shocks are next.
General comment - this under the car work is getting tough for us old guys. I'll be 70 at the end of this month. I have to plan my projects in small doses and the recovery time is directly proportionate to how many times I have to get up and down from the floor! This job kicked my butt pretty good, I probably should have stretched it out over three days instead of two. I plan to keep it up though, since if you stop moving who knows what might happen!
