Knebel
Hi Folks,
i have a problem with my parking and Dashlights. Basically they dont turn on when i switch the Headlight switch to the "Park" position. If i switch it to the full Headlight position the dash/park lights stay off. I can get them to turn on when I pull the switch just a tad back towards the parking lights position, but that is to crazy of a balance between having the light work and not having the headlights on. The Dimmer switch still works tho when i found that sweetspot where the dashlight come on.
I have narrowed it down to the Headlight Switch and that sucker is quite expensive for a NOS part :fucyc:. I had taken it apart, cleaned it ect. and put it back in yesterday, worked one time. Today I took it apart again and filled the grooves in the contacts inside the switch with solder, made it all nice and straight and it did absolutely nothing! The Parking light position is absolutely dead even tho i have tested the switch 25 times with my voltmeter on the contacts and it worked, nothing cut out ect. But in the car it dosent.
I have a relay laying here and am thinking about putting something together to keep the stock switch with the relay turning on the dash/parking lights when i switch on the headlights. I looked at the wiring diagram and have a hard time following this Headlight wiring. I know the dashlights are the Orange wire, and i could figure out the wires for the headlights ( so easy to trigger the relay with the headlisght volts when the lightswitch is on). But how do i do it that the Dimmer still works and i can still dimm the dashlights? where do the Parking and dashlights get their 12Volts from? Wire color?
Anyone done anything like this? Thanks all!
