Ok a little frustrated at this point, car started up good was breaking the cam in, but the car was getting hot like 210 220, radiator was ok, but the temp wouldn't shoot down , just put a new 180 thermostat in. The heater hoses were hot so the coolant was flowing through there we were trying to get the air bubbles out but for some reason it wouldn't drop, thnking bad thermostat right out of the box, the 195 worked good, with the old radiator. the new radiator is fine no leaks clogs coolant is clean when I drained it out. Any suggestions. Water pump is new hoses are clamped good, changing out the bottom hose being I used a stupid flex hose looks smaller than the molded, I don't know at this point. Gonna pick up a new thermostat tomorrow. Mayne because of the spring in the top hose? Any help would be appreciated.
