Timmayy
Just when I thought all was good a new problem arises.
I'm getting vibration while driving. Acceleration and cruising, not on deceleration. I pull into a parking lot and open the windows and listen. I hear little grinding and other little noises.
I pull the front wheels off, passenger side is a little loose. I just give the hub nut a little turn and it's nice and tight.
The drivers side isn't so good. I can't turn the drum by hand. I pull it off and it doesn't feel like the bearings are bad. I can spin the bearings with my fingers. As soon as I put the hub back on it is hard to turn again even with the hub nut loose.
I'm sending it to my buddy in a couple of weeks to do the brakes and check it out.
Just something on my mind. Will the transmission cause a vibration under acceleration also? Maybe its my anxiety but I pulled the trans inspection plate off and made sure all the torque converter bolts were tight.
Any input is always appreciated.
