Gerald Morris
Greetings C-body Moparians! Constantly reminded of WHY I HATE air shocks every morning when I must air up my leaky Monroes, I want to implement a GOOD solution to the problem of lifting Mathilda's rear end 3 inches or so. I like running 235/75/15s in the back, as they do well with Tucson's crappy pavement, but these leave FAR too little room between them and the fender; thus the desire to lift.
I've found several extended shackles which look promising, and I plan to install Monroe "load levellers" (the ones w the coil spring reinforcement, 58577s currently) My concern is that these might not be long enough if I lift the rear end on extended shackles. I also worry about increased shear from side to side on the shackles themselves, and plan to get the stoutest I can find for the purpose.
My question is: Is this a sound scheme to lift the rear end the desired 3-4 inches, or should I just go to a spring shop and be done with it? We have a decent one in town.....
