Knebel
I am going to attempt on the ammeter bypass soon, I have read the mad electric article about it where it says to connect the wires behind the dash and put both ends on the starter relay (to describe that simple).
I just have too much voltage loss when turning on the ignition to reliable feed my switched 12v sources. When I turn on the IGN, I see 11.8v on the switch and when the battery is already a little low, it dosent have enough juice on the IGN wire. I did troubleshoot a lot and it's not the IGN switch or the bulkhead... Another alternative would be using a relay and have the IGN engage that feeding battery power to my switched 12v junction. But that's just more and more wires I don't really want to add.
I already have a new 8ga charging wire from the alternator through a circuit breaker to the batt +. Would it work if unhook the ammeter, cut the wire where the welded splice is, take the whole "loop of wire between alternator and starter relay" out, then run an 8ga wire into the car, Connect it to the welded splice and the starter relay? All it needs is a hot wire to the splice, am I correct? Seems to me that would be the cleanest solution...
