rkrochen
I noticed that my PCV valve had no suction so I pulled the hose from the carb and found the port was completely blocked. I then removed the carb and cleaned the port out however during the inspection I cannot determine where the vacuum comes from. There is no port in the manifold that matches the port on the carb (pics attached). I went to look for a replacement base gasket or carb kit and was using the number located on the fuel bowl which is 1779 and of course it doesn’t correspond with the parts books. At this time I am thinking that the carb has been replaced with a different one which is causing the problem.
Just wondering if this has happened to anyone else. Also does anyone have a reference to the correct part number for the carb.
