I just did a rebuild on my carburetor with the help of my grandpa, new float, and needle and seat too. Even after a rebuild, if it sits overnight, I have to pump about 4-6 times before gas gets to it. If I try to start without pumping, it will almost start, until it seems to use up whatever gas was sitting there. It is not flooded. My grandpa said that carbureted cars all start different, and this is just how this one likes to be started. Is this normal?
My '73 Fury starts hard. My brother's 73 Satellite w/360 starts hard.
First, ethanol in the gas does not help as it boils off quicker. Mopars seem to hold heat under the hood once running and when you shut them down, it is quite possible that the fuel vaporizes after sitting long periods.
My brother decided to add an electric fuel pump back at the tank as recommended by the shop who works on his and other older cars. Says it fires right up now. You would normally have to sit and crank it a bit before it would fire up, even after something like running into a store.
With my Fury, it take a lot of cranking to first fire it up when sitting overnight or even months at a time, so I know the fuel has vaporized. When driving around and I stop, it can still take a little doing to get it to fire up quickly. Pumping the gas a couple times can flood it out and it is harder to start, and then I have tried simply holding the foot to the floor which can on occasion produce a nifty little backfire through the carb. It never catches if I just crank the engine and never touch the pedal. So I crank the engine with the gas pedal slightly open to clear any gas which may have built up in the intake manifold. If it does not start on that crank, then I hit the gas pedal once to the floor, let up on it, and then crank. That usually does it. It sounds like the carb is leaking and engine flooding, but there is no evidence of this - so I just deal with it for now and use my starting technique as I don't drive it much anyway.
HOWEVER, keep in mind that there could be other problems causing this. A dirty or plugged gas filter or air filter can add to the problem. Any air leaking into the fuel system, like a cracked or split rubber hose between the tank and fuel pump may not show signs of a leak because it is not pressurized. It can still draw air in, allow the gas in the line to seep out or evaporate, or allow the gas held in by capillary action to trickle out back into the tank.
Check hose clamps to make sure they are tight and not positioned incorrectly or cranked down so tight they crush the hose cutting off fuel supply. Here is my take on some of MY start problems. Went to take my car for a drive, got it fired up, backed into my driveway and then shut it down to pop the hood and give it a once over. For no reason I reached down and grabbed the fuel filter near the fuel pump. When I did, I got a handful of gas, but there was no signs of a leak or smell of gas because it was on the tank side of the fuel pump. Further inspection revealed the hose was loose and the clamp simply spinning around on the hose. I parked the car. Have not tackled the job yet, but figure this was certainly adding to my hot start problem. Will put new ethanol friendly rubber lines on and new filter and see if there is any difference.
Make sure you have a good strong/fully charged battery as well.
