Changing front side marker bulbs
Electrical & Ignition
  1. charles messler
    charles messler Member
    50
    12
    Feb 7, 2016
    Long Island new york
    Hi all,
    I took the 68 fury for inspection and the guy told me to put the side marker lights on and make them work. How do you change the front light bulbs without breaking the socket?
  2. mrfury68
    mrfury68 Well-Known Member
    891
    321
    Jul 15, 2015
    Bethel Park PA
    Soak them with a good penetrating oil and use a good pair of channel lock pliers. The longer you can soak them the penetrating oil will have more time to work. Patience is required. Good luck.
  3. Polara_500
    Polara_500 Senior Member FCBO Gold Member
    2,414
    1000
    Apr 17, 2011
    Up North, you betcha!
    You do know they aren't on with the headlights, don't you? Only illuminate in the 'park' position.
  4. charles messler
    50
    12
    Feb 7, 2016
    I know but I don’t know why the guy is making such a big deal about them. I’ve been driving a 68 fury for 28 years now and nobody has said anything about those marker lights. I got the socket out of one without damaging the housing but I think I need new sockets.
  5. FURYGT
    FURYGT Senior Member
    2,361
    993
    Mar 11, 2017
    Middletown, CT
    The post is about side marker lights, not the parking lights in the grille.
    Those lamps ground through the mounting nuts and sometimes it is hard to get a good ground. Run a jumper wire to ground from the nut and see if they work.
    • Agree Agree x 2
  6. Polara_500
    2,414
    1000
    Apr 17, 2011
    Sorry, Dain Bramage kicking in.......... :thankyou:
