TXPinkSkurtz
I'm replacing the top on my 1968 Fury III convertible and was wondering if I should go with glass or plastic (it currently has plastic, but it's yellowed and cracked)?
Leave it in. It all folds up into the trunk.I forgot to ask if glass will fit back in the boot when the top is down, or if it must be taken out first, before lowering the top?
Considering you live in NY state and just to add to this warning . Be very cautious operating the top mechanism in extremely cold temperatures. I've heard more than a few anecdotes of shattering rear glass in those conditions including from the former owner of my car.Only warning is to not put stuff in the trunk where the top folds into. You can break the glass.
Generally speaking, I don't put the top down in the winter....Considering you live in NY state and just to add to this warning . Be very cautious operating the top mechanism in extremely cold temperatures. I've heard more than a few anecdotes of shattering rear glass in those conditions including from the former owner of my car.
Probably has a heated shop...wussGenerally speaking, I don't put the top down in the winter....
I've been cold enough times in my life to not be a tough guy about it any more. Cold hurts the old bones too much these days.Probably has a heated shop...wuss
If the zipper is troubling you, you could run across it with a pencil lead several times. Should smooth it out.My dad told me a story about the '67 Sport Fury convertible he used to have. Right after he got it, he went to put the top down. He didn't know that you're supposed to unzip the zipper around the glass first, and that it rests separately inside the well. Top went down and POP went the glass.
I guess you're supposed to unzip the plastic windows like in my '66 Chrysler as well. Whoever owned mine previously never did and it already had a horizontal crease in the middle of the window. I only worked the zipper once, and it was so hard to zip back up, partly from lack of use, that I never touched it again.
I presume the top mechanism is basically the same for pre-67 with plastic vs 1968+ with glass, and his car tried to fold the glass window the same way my plastic one folds.
I never unzip the glass window in my '70.My dad told me a story about the '67 Sport Fury convertible he used to have. Right after he got it, he went to put the top down. He didn't know that you're supposed to unzip the zipper around the glass first, and that it rests separately inside the well. Top went down and POP went the glass.
