New build 383, 030 over, 915 heads, correct preload on lifters, new ignition parts, 12 degree initial and 32 degree total @ 2.200 rpm, 95 octane gas.
I thought it was a exhaust manifold gasket leak but I replaced the gasket and looked at the gaskets i replaced and they are okay and no sign of leaking. I can not find any leaks anywhere in the exhaust system.
It's total quiet at idle or just revving. It has to be under load. Cold or warm doesn't matter, it's ticking under load.
The ticking frequency sounds like one of the eight cylinder cycle.
Any sugesstion?
Any sugesstion?
