sprice
I was checking the exhaust gasket against the heads and exhaust manifold and am finding the matching is off slightly, or can be considerably off depending on where the gasket ends up when fastened. Its a Fel-Pro gasket from an overhaul gasket set for a 440. When I apply the gasket and center the front bolt hole, the rear bolt hole and port is out as in the photo. Has anyone experienced this and do the exhaust gasket holes have to be so large? So much play in there.
I could cut and trim the gasket however with so much play in the bolt hole, its still a nit and miss. Thanks,
