Matt, I would definitely go with new springs.
I'm not....If motivated your looking at...
I'm not....
I had a problem finding them, too.Stan, if you dont mind me asking.. Where are you getting the strut rod bushing kit? I havnt really come across any for formals.
Nothing would get done.Then you need another in the garage, the model without the timer
I think this is the complete list. Anything missing?
1. Strut Rod Bushing Kit. (1)
2. Tie Rod Adjusting Sleeve (2)
3. Tie Rod End - Outer (2)
4. Tie Rod End - Inner (2)
5. Control Arm Bumper - Upper (2)
6. Control Arm Bumper - Lower (2)
7. Ball Joint - Upper (2)
8. Ball Joint - Lower (2)
9. Stabilizer Bar Bushing - Pr. (1)
10. Stabilizer Bar End Link - Left - (2)
11. Stabilizer Bar End Link - Right (2)
12. Strut Bar Bushing (1)
13. Control Arm Bushings - Pr. - Upper (2)
12. Control Arm Bushing - Lower (2)
13. Idler Arm (1)
14. Pitman Arm (1)
15. Shocks - Pr. (1)
16. Torsion Bar Seals & Clips - Pr. (1)
17. Torsion Bar Tool (1)
Check twice - Order once
Cotter pins: Gotcotter pins! Grease ! And...... Patience !!!!!
Thank you Stan!!!
Thanks for instilling a little more confidence in me.Commando,
I am midway thru my suspension rebuild. I have all the front suspension pieces off the car. It is not really that bad. Popping the joints between the part was the hardest part. I bought a special puller from sears to take care of those. I also had to buy a special socket to take the ball joints out of the upper a-arms.
I have most of the parts cleaned and will be soon painting them. I plan on upgrading the torsion bars. Be sure to take the torsion off the lower control arm before trying to pull the bolts out of the spindle/brakes.
It was thrilling to see the original paint inspection marks on the spindles and tie rods. They have been coated in oil/dirt/gunk since I got the car in 1988.
Good Luck
